94 service light--how to turn off
Old Feb 14, 2005 | 12:39 AM
gferris5's Avatar
Default 94 service light--how to turn off
Hey
I searched for this but could only find info on how to turn late year '95's off.
I couldn't find any neat little rubber access plug on my speedo cluster.
I have a 1994 with the light on. I would like to turn it off after I change the oil in a couple of weeks. (I changed the oil right after I bought it, so the light came on a little before it was needed). Any info would be greatly appreciated.
Thanks
Old Feb 14, 2005 | 01:49 AM
Default RE: 94 service light--how to turn off
Bye the washer fluid fill there should be your diag plug.Use A7 stick the wire in A7 and press the button the number of times then wait for it to light up then do the same 3 more times to reset it.It is either 4-1-5-1 or 5-1-4-1 I believe it is 4-1-5-1 try that and let me know.
Old Feb 14, 2005 | 01:52 AM
Geetarslim's Avatar
Reset-procedure servicelight: switch ignition on, open the diagnostic-socket in the motorcompartment, put the plug in opening 7, press the small button 4 times, wait untill the led lights up steady, press the button once and wait for the led to glow steady, now press the button 5 times and again wait for the led to show a steady glow, then press the button one more time and wait for the led to flash rapidly. Now the servicelight on the dash should be out. It will light up again after 15.000 km. This works only on pre 1996 models.
I got this from a Volvo 850 enthusiast's website, it has some other interesting tidbits as well, I DIDN'T try it yet,since I am still researching my 94 volvo 850 my dad just gave me. HERE IS THE WEBSITE:
http://welcome.to/volvomania. the site name is volvomania, check out tuning tips. He has some interesting RACING stuff too. HOPE THIS HELPS.
Peace and Blessings,
MEL
Old Feb 14, 2005 | 10:01 AM
The link does not work.
Old Apr 7, 2005 | 02:41 PM
CFGVolvo850's Avatar
I tried resetting the service light using the code (4-1-5-1), but it didn't work. When I press the button, the light never stays on continuously, so that I could enter the proper code. Do you have any other suggestions? Thank you.
Old Apr 7, 2005 | 03:37 PM
floryed's Avatar
The decmal point at the end of the connection is what screws it up. Double click on the site, and then when it gives you an error, edit the address by deleting the decmal at the end.
Old Apr 7, 2005 | 03:39 PM
floryed's Avatar
Also, make sure you put a back slash, or a forward slash (whichever is the / symbol).
Old Apr 8, 2005 | 01:23 PM
Actually, I read on www.volvospeed.com that some Volvo 850 have a reset service light button on the instrument panel, behind a rubber grommet (left center). I removed the grommet and pushed in the button. IT WORKED!!!
Thanks to those who responded.
Old Apr 8, 2005 | 04:17 PM
You have a special one.There was very few made with that setup.
In the 4 years at the dealer so far I have seen 3 of them like that.
Old Apr 8, 2005 | 05:20 PM
JimKW's Avatar
I don't have one. I am going to try and reset my Service Light tonight. I will let you know if it works with the code.
Old Apr 10, 2005 | 12:54 PM
JimKW's Avatar
It worked. Pretty easy. How do I turn it off on the V70? I also want to turn out the Check Engine Light on both of them. Disconnecting the battery did not work on the 850. I do know my radio code too.
Old Apr 10, 2005 | 12:58 PM
The 850 to pull codes and clear the Check Engine light follow the link.
http://www.troublecodes.net/Volvo/
The V70 you will need an OBDII scanner or bring it to someone that has one.
Some Auto parts stores will pull codes and clear them as well.
Old Apr 10, 2005 | 01:08 PM
JimKW's Avatar
What about the Service Light on the V70? Thanks again. You must really like helping us dumb Volvo owners!
Old Apr 10, 2005 | 01:21 PM
You will need a service light reset tool for the V-70.
If you do a search online you can find one pretty cheap.I will put a link in here this one is pretty expensive.But you will know what one looks like.
http://www.ipdusa.com/ProductsCat.as...564&RootID=629
As far as helping.I have the knowledge and like to share.I know the feeling on not having alot of money and I like to help others save money.
We grew up on the very low side of money.I started working on cars at age 14 and kept going ever since.
If I had help like this when I was younger I would have a lot more knowledge.
Old Apr 10, 2005 | 01:34 PM
JimKW's Avatar
I get a code 315, but the check engine light stays on when I tried the clearing procedure.
Old Apr 10, 2005 | 02:02 PM
It should clear unless you have a permanant fault in the evap valve or something like that.My book says a problem with the evap. system.The evap valve is located on the cooling fan.There is a hose that goes from the intake to the valve then the other hose runs under the car.Check the hose that runs under the car for holes or make sure it is not cut or flattened.
Jakeness
Jun 30, 2012 02:36 PM
nottelybill
Jan 27, 2011 05:41 PM
96960Chris
Oct 27, 2010 11:43 AM
VlvoGrl
Jul 8, 2005 11:22 PM
s40guy
May 31, 2005 10:12 PM
