94 wagon - changing rear shocks
By far the easiest shock change you will ever do. While your in there take a look at the upper shock mounts. Make sure they have not started separating. Here is an example of when they break.
http://s566.photobucket.com/albums/s...t=83bf75e4.mp4
ibi- really an easy job, I changed a set once in my office parking lot at lunch time. without even jacking the car up. BUT here is the kicker- if you change the shock mounts, the mounting bolts might be frozen in there. One side of mine came out OK, the other side both studs broke. And I went slow slow slow. Out, in. Out a little bit more, in. Out, in. Out...snap! ! Might want to have your drill ready. Dave
umbalaxx
05-31-2015 12:32 PM
parrym
07-13-2007 12:51 PM
