95 2.3 Turbo, part # for wideband O2
Old Jul 28, 2010 | 10:25 AM
Default 95 2.3 Turbo, part # for wideband O2
I infrequently set a code for the O2 sensor on my wagon. I'm going to replace both O2's and am also slowly upgrading the system for more power. At some point I'd like to replace the turbo, exhaust with 3" and get a reprogrammed ECM. If I'm going to replace the O2's would it make sense to go with the stock ones for now or upgrade to wideband sensors? I was reading that they give the ECM better info on modified engines. Anyone have a Bosch, NGK or ..... part number for ones that would work on the 2.3 turbo?
Old Jul 28, 2010 | 12:21 PM
gilber33's Avatar
Wideband is different from O2s. You don't use a wideband instead of an O2 sensor. It's a completely separate bung and sensor and gauge.
Old Jul 28, 2010 | 07:11 PM
fcpgroton's Avatar
Former Sponsor
A wideband would be used with a wideband gauge, not the main o2 sensor.
Old Jul 28, 2010 | 08:01 PM
gilber33's Avatar
The type of sensor used in conjunction with the existing O2 sensor is a narrowband gauge, but those are useless.
memphis
Oct 25, 2016 09:01 AM
Titan Joe
Nov 10, 2015 12:25 AM
Kiss4aFrog
Nov 20, 2013 11:19 PM
sillygily
Jan 12, 2013 02:05 PM
anthony4813
Sep 20, 2012 09:22 PM
