95 Volvo 850 Turbo.. Mre then just bad gas???
Old Jan 11, 2014 | 06:30 PM
Kayte Bridge's Avatar
Default 95 Volvo 850 Turbo.. Mre then just bad gas???
I recently made the mistake of putting gas in my 95 850 turbo while a tanker was there filling the tanks I made it to work with no problems but on my break i went out and started my car and was letting it idol and it chugged a little and died. Later it was still doing it, the less gas left in the tank the worse it got but then more things started happening. When it would die and i would try to restart it there would be power but wouldnt start so I would try again to start it and there would be little to no power like every thing is drained and then if i wait a minute there is full power and it starts again. It has also started accelerating on its own. I put a 4 in 2 octain booster/water reducer/other stuff in a full tank of gas, change the fuel filter and spark plugs and it is still dying. I was able to drive it for 2 1/2 days with no problems then i just died right after i started it and it took me 5+ minutes to get it started again. If any one knows what could be causing this i would appreciate the help thanks
Old Jan 12, 2014 | 12:28 AM
Try not to tie your problem to the tanker dropping off fuel.
It sounds more like you might have a fuel pump relay that's starting to fail.
Old Jan 12, 2014 | 01:17 PM
Do you have a CEL?
Old Jan 12, 2014 | 03:46 PM
I wasnt blaming it on the tanker i was merely explaining what happened.
anglveyes
Mar 30, 2014 07:10 PM
Dennis Bor
May 30, 2011 11:14 AM
mstrplmber
Jun 26, 2010 04:10 PM
pcgold
Jul 16, 2009 08:44 AM
Earwig225
Dec 12, 2008 06:21 PM
