96 850 engine run-on (dieseling) and high idle HELP!
Hi guys, I was wondering what can i do to fix dieseling or engine run-on? The idle is always near 900 to 1000 when it happens, I know that the 96 idle is should be around 850. I was wondering is there anything I can do to fix this?
Could it be the spark plugs...the car is my family's and its old. I am not sure what has been replaced and what has not.
Thanks guy
Thanks guy
Wow, typically dieseling is caused by carbon deposits. I am trying to think of what could do it. You would need fuel, compression and spark to make a diesel happen. With the engine off there would be no spark, but if there is carbon build up that could be still glowing hot enough to ignite fuel. Compression is there so fuel may be your culprit. Possible leaking injectors?????
I vote on the leaky injectors- fuel injected cars should never diesel... unless the injectors are leaking. High idle speed WILL cause a car to diesel if there's a supply of fuel. Incidentally, the leaking injectors could also- indirectly- cause the high idle! The ECU would see rich mixture at idle, and would slightly increase airflow to compensate... thus increasing idle a tiny bit. Old, carbureted engines would diesel if the idle was set too high, or if you shut off the engine with the gas pressed a little bit.
And no, you don't need spark to make a car diesel. Dieseling is when an engine runs... well, like a diesel- where the heat from compression is enough to ignite the fuel mixture. This is how excessive carbon deposits would cause dieseling- they actually increase compression.
But I don't think your problem is caused by carbon deposits. (or, at least, it's not the primary cause) the fix for leaky injectors is to replace them- to check them, pull the fuel rail off of the manifold with the injectors and fuel lines still attached. Turn the key to the on position, but don't start the car. Then, observe the injectors- does fuel drip out? Yes? Change the dripping injectors. Now, to clean carbon, usually a treatment with seafoam will do the job- basically, you VERY SLOWLY and CAREFULLY run a can of seafoam through a vacuum line while holding the throttle open slightly (2,000-3000 RPM) by hand, a little at a time- too fast, and you'll hydrolock the engine.
apexieclipse
03-13-2011 01:25 PM
repeatclicks
08-31-2007 04:37 PM
