96 850 just quits when ac or deforst is on.
Old Mar 28, 2008 | 08:20 AM
jquick1's Avatar
Default 96 850 just quits when ac or deforst is on.
Help, THIS DOESNT HAPPEN IN COLD WEATHER. When you run the ac or defrost, when you come to a stop the car shuts off, and doesnt want to start back. could it be the Temperature Sensors ,AC relay(cant find anyone who sales them) or power stage. RUNs FINE WITHOUT THE AIR ON.
thanks Dwayne
Old Mar 28, 2008 | 08:45 AM
Psaboic's Avatar
Default RE: 96 850 just quits when ac or deforst is on.
After that car stalls, if you shut off the AC or turn the defroster off, will it start back up again?
Old Mar 28, 2008 | 09:58 AM
JPN's Avatar
JPN
Could be the idle control/boost problem.
If you could specify the model year of your 850, we can better help you. I do not believe it is the relay that is causing the problem, but in case if you need one:
This is blower relay and I'm not sure if there is another relay to the A/C.
http://www.eeuroparts.com/productdet...&code=9363
JPN
Old Mar 28, 2008 | 10:08 AM
jquick1's Avatar
1996 850T with 247398miles
Old Mar 28, 2008 | 10:11 AM
jquick1's Avatar
yes its starts back, sometimes rite away others it takes about a min.
Old Mar 28, 2008 | 10:26 AM
JPN's Avatar
JPN
I would visit an AutoZone if there is one near you and have them do a free OBD-II diagnostic. I would then post their findings on the OBD-II scanner. The OBD-II port should be located in front of the shifter, under the coin holder. If there is no AutoZone near you, other franchise parts shops may do the same service. I believe a dealer would charge $100+ just to read the codes[8D].
See if you can wait to receive a reply from Moderator Tech.
JPN
Old Mar 28, 2008 | 11:47 PM
Psaboic's Avatar
Since it starts back up again after it happens, I'm inclined to agree with JPN, that it is an idle control problem. Most (if not all cars) will automatically step up the idle a bit when the AC compressor kicks in to keep the engine from bogging down or stalling. As I'm sure you know, the AC compressor kicks on when the defroster turns on, so......
It would also be a good idea to see if any codes are stored just to give you more of an idea on where to start troubleshooting..
Please keep us posted
Old Mar 29, 2008 | 09:02 AM
Sounds like the A/C compressor is getting ready to seize up.
Old Mar 29, 2008 | 10:09 AM
Psaboic's Avatar
Tech, that is definitely something that could cause the problem, and is something I never thought of! How prone are the compressors to seizing up?
Old Mar 29, 2008 | 10:17 AM
Not very but is very possible.
aavmaj
2001-2013 model year V70
16
May 26, 2014 08:38 PM
Magic_Don
May 9, 2010 11:03 PM
SR Heer
Nov 1, 2007 06:11 PM
SR Heer
Nov 1, 2007 10:53 AM
dbehr
Sep 30, 2004 09:46 AM
