'96 850 Starts, runs for 10 seconds, then quits...
Old Sep 30, 2004 | 01:49 AM
dbehr's Avatar
Default '96 850 Starts, runs for 10 seconds, then quits...
Fellow listers,
I have a '96 850 GLT, non-turbo w/20 valve engine 5254. The problem is that after starting, it runs for about 10 or seconds, then dies. If, when running (not in gear), you press the accelerator to the floor, it will maintain high speed and you can moderate the speed at between 3-4,000 rpm. As soon as you lift your foot off the accelerator, however, it dies.
The codes are 1-1-2, translating to P1401 - Fault in ECM and P0115, which I don't know.
I've replaced the plugs, changed both computers, the ignition module and still no result.
I disconnected the air mass meter plug, which should allow it to idle. No dice.
There are no vacuum leaks. The segmented snorkle hose had some leaks, but was duct-taped to seal the leaks.
Nada.
What's the scoop with this car?
Hope somebody has the answer...
Old Sep 30, 2004 | 09:46 AM
Default RE: '96 850 Starts, runs for 10 seconds, then quits...
Could possibly be a bad idle motor from what you are explaining you are having most of the problem at idle.Another possibility could also be low or high fuel pressure.Have you checked fuel pressure?I will keep racking my brain for more ideas.
southislander
Volvo C30
Mar 4, 2015 03:38 PM
johnb317
May 13, 2013 12:43 PM
xaiox20
Apr 30, 2012 04:15 AM
victory
Feb 11, 2009 07:39 PM
Gordont
Jun 2, 2007 11:04 AM
