96-850 Mass Air Sensor
Old Dec 12, 2010 | 12:53 PM
Rosew6211's Avatar
Default 96-850 Mass Air Sensor
After recent fill-up, engine bogged dpwn and died. Changed fuell filter, checked rail pressure etc to no avail. Got a code readerr; Results ; Mass Air problem. Suspected defective sensor but disliked shelling out $156 for new Borsch on net and find sensor wasn't bad. I suppose all knew except me that the best check is to disconnect the sensor and start car. This puts engine in limp mode to get one on the way. After disconnecting motor ran OK with a little hesitations at low RPMs and as soon as I reconnected, engine would shortly die. Put a new MAS in. Runs like a charm now.
Old Dec 13, 2010 | 09:28 AM
fcpgroton's Avatar
Former Sponsor
Good to see you got her running well again. I just had a similar issue on my mother-in-law's Mercedes. Changed the sensor and runs a lot better now. I do agree with you though, you never want to shell out 156 dollars and it not be the problem. You could have always returned it though.
BavarianTech
Jun 14, 2007 08:52 PM
jerryman
Oct 28, 2006 07:35 PM
WagHag
Mar 28, 2006 09:24 PM
reg
Jan 1, 2006 11:41 PM
floryed
Apr 14, 2005 10:51 AM
