How to test an Air Mass Sensor on a 93' 850?
Old Jun 13, 2007 | 01:26 PM
BavarianTech's Avatar
Default How to test an Air Mass Sensor on a 93' 850?
Hey gang,
VIN: YV1LS5504P2086953
Build Date: 05/93
Mileage: 142857
Now I have searched and read that if the Air Mass Sensor is pulled and the car starts and runs (with revs I presume) and if the sensor is plugged back in and the car idles rough and does not rev or accelerate, the the Air Mass Sensor is bad.
Now, to test the Air Mass Sensor, do I unplug the electrical harness from the Air Mass Sensor and test, or do I unplug / take out the Air Mass Sensor and then run the test?
Thanks in advance for your advice / help!
Old Jun 13, 2007 | 11:04 PM
JPN's Avatar
JPN
Default RE: How to test an Air Mass Sensor on a 93' 850?
Hi,
The MAF sensor is noted for causing trouble, but it's actually the wiring. The sharp bend causes intermittent problems. Try wiggling the wire to see if the engine responds. If not, you may need a new sensor.
JPN
Old Jun 14, 2007 | 08:52 PM
J Telectro's Avatar
Hi BavarianTech and Kanji,
I think you should disconnect the harness. You want to find out
how the car runs without the MAF's influence. I am not sure
whether you need to turn off the engine before disconnecting
it. As JPN mentioned check the wiring first. If that doesn't
help then disconnect the sensor from the harness. If the sensor
does appear to be bad, they can sometimes be cleaned.
Kanji, I hope you're doing ok and will get your internet connection
back soon.
Best regards, John
Rosew6211
Dec 13, 2010 09:28 AM
lysmykita
Oct 23, 2008 06:14 PM
reg
Jan 1, 2006 11:41 PM
floryed
Apr 14, 2005 10:51 AM
Pandrew
Oct 10, 2003 09:35 PM
