96 850 turbo turns but won't fire - P0300 Error Code
Old Jun 23, 2013 | 04:35 PM
brad2388's Avatar
Default 96 850 turbo turns but won't fire - P0300 Error Code
So after driving my car a little roughly for 20 minutes because I was late for an important meeting it failed to start 5 minutes later. I have the P0300 code and nothing else.
I replaced the battery 3 or 4 months ago. I started with the plugs and the top of the engine was soaked in oil. I cleaned up the oil and put on a new cap, replaced the plug wires and the plugs.
I attempted to replace the fuel filter but it is stuck because the 12 mm bolt will not come out. I attempted to shimmy it and unplugged both ends. Fuel pours out pretty easily so I figure it is not a filter problem.
I have heard that it may be a fuel pump issue. I've read that I should listen for the pump but when I attempt to turn on the vehicle all I hear is it attempting to start. Has anyone had a similar problem or have an idea of what may be happening? I have also heard that there is a problem fuse that controls the fuel pump that may have gone bad.
I received help from a previous thread that I started but I figured I would start a new one with a title that better describes my problem.
Old Jun 23, 2013 | 10:16 PM
Old Jun 23, 2013 | 11:05 PM
brad2388's Avatar
Thank You. I'll give that a try tomorrow. I hope it is as easy as that.
Old Jun 24, 2013 | 03:03 PM
Don't we all.
Old Aug 17, 2013 | 06:50 PM
brad2388's Avatar
Hey guys, sorry it took me so long to reply. They ended up replacing my camshaft position sensor. Thanks for all your help!
Stb7
Nov 6, 2013 09:12 AM
iamcanadian
Jul 15, 2012 05:26 PM
nathan7h
May 18, 2009 07:50 PM
