96 850 turbo wagon - won't start
Old Jan 17, 2005 | 03:21 PM
babydoki's Avatar
Default 96 850 turbo wagon - won't start
My 850 is out in the cold - it's -10 degrees on average where I live right now - I have kept the tank nearly full and added iso-propyl alcohol to keep away from condensation, but yesterday my car wouldn't start after only 3 hours out in the cold. If I try to start, it just catches at the beginning a little and then won't spark really if I keep holding the ignition on. Any ideas for cold weather troubleshooting??
Old Jan 7, 2011 | 11:32 AM
boxpin's Avatar
Originally Posted by qutum
this post is great.i like the idea of present.the way you adopt is nice always try to do nice work.keep it up.your ideas definitely worthy. I believe in love,loyalty and respect and i hope one day to reap the benefits.i am waiting something new from your side.good luck
mcse 2008 | cissp exam questions | testking ccna | oracle certification dumps
spam!!
Old Jan 7, 2011 | 03:14 PM
vjaneczko's Avatar
First, welcome to the forum.
Where are you located? If it's that cold, do you have a engine block heater? Is this the first winter you've had the 850? Any maintenance done to it recently?
A few thoughts; check for spark, fuel & air. Make sure the plugs & wires are good, you have fuel pressure and airflow is not restricted.
Another thought; move someplace warm!!
Old Jan 7, 2011 | 03:23 PM
Henry10's Avatar
I am not 100% clear -- is the starter cranking the engine, but no start? Tune-up (wires, plugs, distributor, rotor) done? Battery condition? CEL on? Pulled codes?
Assuming you are using isopropyl in the correct amount / mixture, right? (I have no idea what that would be). I would buy Gas Antifreeze and use it according to instructions on the label.
ashort
Jun 11, 2015 09:40 AM
dholdren
Aug 4, 2010 06:18 AM
jebarnes
Mar 22, 2008 05:07 PM
parmotinc
Dec 12, 2006 12:08 AM
