96 850 Turbo. Water Splashing Sound
Do you have any warning light on....for example the low coolant light? Could it be burnt out or not working and your super low on radiator fluid enough that your blowing air through your heater core and have now blown your head gasket so water vapor is coming out the tail pipe? Just a thought.
You may have water in your turbocharger. I have had this symptom, remove your top intercooler hose and see if there is water in it.
Mine was caused by my own stupidity, I degreased the engine without the hose on, but if water has gotten in via your air filter assembly it may be the issue. Also water may be leaking out of the coolant line in the turbocharger if the coolant is a little low. It only takes a small amount to make the sloshy sound.
