96 GLT instrument cluster not woking in cold weather?
Old Feb 22, 2024 | 09:01 AM
rcvolvo's Avatar
Default 96 GLT instrument cluster not woking in cold weather?
It's cold here in Florida and I noticed this morning that my engine gauges don't work until the car warms up. The clock is not effected. Anyone have this happen? Is there a fix?
Old Feb 22, 2024 | 03:19 PM
It sounds like there's a connectivity issue (ie cracked solder joint etc) that is opening up when the parts are cold. The easy fix is to drop in a replacement (used) cluster. Check ebay - I'd expect to pay $50-75 for the cluster and it takes about 30 minutes to open the dash and swap it out. There should be how to's on Youtube (same procedure is used to pull the cluster to repair a broken odometer gear). Just remember the turbo and NA have different clusters (ie with/without boost gauge). Also, this would be a good time to replace all the backlighting bulbs.
LucasArts547
Sep 13, 2021 12:52 PM
PavelG
Mar 18, 2012 01:11 PM
a16129014
Jan 30, 2010 12:41 AM
chadman551
Dec 19, 2009 07:33 PM
