96 turbo useing lots of gas
Old May 23, 2009 | 10:08 AM
jquick1's Avatar
Default 96 turbo useing lots of gas
i cant figure out why my car is only getting about 10-15miles per gallon. checked for leaks, tune up about 6months ago. anyboby know why. thanks so much
dwayne
Old May 23, 2009 | 01:36 PM
boosted8fifty's Avatar
Check and see if your car is throwing out o2 sensor codes..
Old May 24, 2009 | 11:46 PM
blondetamadrummer's Avatar
Ive been having the same problem, but with a 95 GLT 5-speed. I diagnosed the problem and figured out that my Mass Airflow Sensor and my Oxygen Sensor's were bad. They're not that expensive online.
First thing first though. Try to find an auto place that will read OBD II codes for free. If you manage to find a place that will do that for you, then tell us what the codes read.
If your codes say thats its running too rich (which is more that likely is) then you may have a problem with your mass airflow sensor or oxygen sensor or possibly both.
You can try and spray some Carb & Choke cleaner into your air intake. Just take out the air filter and spray it in the intake. That gave me a temporary fix and helped my car out a bit.
I cant help anymore untill you have the codes pulled from your car. After that, everyone can help alot more.
Also, I forgot to ask: is your car having problems with acceleration i.e much slower than normal or disrupted powerband?
DeadLast
1998-2000 model year V70
Apr 10, 2014 08:22 AM
Collarbonecam
Dec 17, 2013 09:09 PM
codynidaho
Dec 3, 2011 08:14 PM
jollygoodgold
Jul 16, 2007 12:06 PM
90_740turbo
May 23, 2006 12:17 AM
