soft brake pedal.
Old May 24, 2009 | 10:58 AM
krs2's Avatar
Default soft brake pedal.
I've got a 94 turbo wagon w/ a soft brake pedal.I've bleed the brakes twice. There is no leaks,I'm guessing master cylinder?
Old May 24, 2009 | 11:28 AM
I would say that as well. They are not common to go bad either.
Old May 25, 2009 | 12:24 AM
gdog's Avatar
Did you bleed the system using a pressure bleeder, or did you use the old two-man pump the brake pedal and bleed method?
Frankly I almost never get the latter method to work on modern cars with ABS modules; I got myself a cheap pressure bleeder and haven't had a problem bleeding brakes since.
Did you have the brake hydraulics open for some other repair recently? In other words, did something cause the soft pedal in the first place? Or did it just appear on its own?
Old May 25, 2009 | 08:14 AM
Psaboic's Avatar
I agree with the pressure bleeder. They are nice to have/use
stormy76
Aug 19, 2011 09:10 PM
ecberr
Oct 8, 2009 04:54 PM
daver80
Jul 13, 2009 10:25 PM
cruzcountryxc70
Engine & Internal
Apr 28, 2008 05:42 PM
hosey82
Aug 1, 2007 07:40 PM
