97 850 T5 O2 Sensor
Old Dec 17, 2010 | 07:13 PM
TOAB's Avatar
Default 97 850 T5 O2 Sensor
Well, to make a long story short, I got cheap and bought a Bosch O2 sensor that needs to be spliced in. Now, I'm having a hell of a time finding a wiring diagram online.
I was hoping that someone could simply tell me what color the Signal, and ground wires are. I'm guessing the Heater wires don't matter as far as polarity goes, so correct me if I'm wrong.
Thanks.
edit: Just to clarify I only need to know about the wires already existing on the car.
Old Dec 18, 2010 | 10:38 PM
I'm not sure but if you go cheap, it might be best to get a used sensor from the yard.
Old Dec 18, 2010 | 10:52 PM
TOAB's Avatar
Well, I guess I'm just going to have to spend time out in the cold.
Might just end up tossing it in, clearing the code, and swapping wires until the CEL stays off.
Old Dec 18, 2010 | 11:57 PM
ibified's Avatar
sometimes the universal O2 sensors WONT stop giving youa check engine light.
Old Dec 19, 2010 | 12:44 AM
TOAB's Avatar
Well voltage is reading slow on the stock one so it's not cutting it, if the scanner responds when the throttle gets blipped or stabbed I'll be happy.
If the computer gets a good voltage reading it should keep the light off, I'd just rather get it wired in correctly the first time.
Old Dec 19, 2010 | 09:51 PM
You can drive forever with a bad O2 sensor.
Old Dec 21, 2010 | 02:00 PM
TOAB's Avatar
And because the ECU is thinking you're running lean it tries to compensate and your car doesn't run as well as it should.
FYI for those wondering, the wires are the same color.
soduku007
Oct 7, 2019 04:01 PM
ruggles
Mar 3, 2010 04:19 PM
mctan
Feb 2, 2010 03:16 AM
Scanman
Jan 28, 2010 07:01 PM
sabydady
Jul 7, 2009 04:58 PM
