97 t5 wagon getting 8-10 mpg
Old Jan 29, 2012 | 05:32 PM
97T5WAGONPIMP's Avatar
Default 97 t5 wagon getting 8-10 mpg
HI i got a 97 850 t5 wagon with 135k miles i used to get 15-19 city . about a month ago i went snowboarding and on the way home car started to run like crap. so month later i drive the car give it a tune up and my mpg's are still @ 8-10 city.no codes nothing so any help would be great
Old Jan 29, 2012 | 06:54 PM
There is something going on...
What did you do as the "tune up"?
Are the brakes pulling?
Did you scan for codes?
Do you have a fuel leak?
How are you measuring your gas mileage?
What do you consider "run like crap"? Did it toss a code?
Did you read the "how to improve gas mileage" thread?
If plugs were replaced, what type of plugs were installed?
What are the current plugs gapped at?
Old Jan 30, 2012 | 12:02 AM
no fuel leak no codes it ran like crap coming down the mountain and got sucky gas so i done the tuneup and it helped out a lil but the car still feels like its hitting boost cut and when i punch it the mpg's and fuel guage drop i spent over 100 bucks in 2 days in gas in this thing it will start to get better after i reach speed limit and stay there it will go to 13-15mpg on highway but soon as i press gas the miles drop like **** i never seen. b4 this i used to get 15-19 city and 27-33 highway. i did plugs tranny flush oil injector cleaner im stuck i cant keep driving this car its killing me in gas
Old Jan 30, 2012 | 09:54 AM
When you say no codes have you hooked up to the OBDII port and attempted to pull them or are you just saying you don't have a check engine light on ??
With your symptons I'd check to see if anything is in there even if the lights not on. It can store pending codes. Something that is getting out of it's parameters but isn't considered as failed yet.
Check the fuel pressure regulator vac line to see if you can smell or see any fuel at the regulators nipple or inside the vac line. If any gas is present, any at all you have a ruptured regulator and the intake will be sucking in raw gas through that vac line and possibly cause the problems you are having.
Second guess would be a bad coolant temperature sensor that is sending a very low temperature to the computer that is sending the engine management computer way rich.
Your gas mileage sucks but how does the engine run ?? Does it feel like it's missing at all ?? Did you check or replace the cap, rotor and wires as most would do in a tune up, you didn't say.
What did the old plugs look like and what did you put in and at what gap ??
Old Jan 30, 2012 | 11:06 AM
matt01's Avatar
Could you write properly? First step to the problem i think.
Old Jan 30, 2012 | 04:52 PM
this is how i ****ing write tried of ****ing people saying the same **** this is not going to help with my car.anyway i used scan tool to check for codes none wires and cap are like new still no leaks and my temp gauge reads past half
Old Jan 30, 2012 | 05:38 PM
Turkey_Sandwich's Avatar
The first thing I'd check is ******. After that I'd look at the ******. Lastly, I'd have someone put a **** on the ***** and check the *****.
Anyway. What is "run like crap"? Is it misfiring? Is it hard to start when cold or hot? Does it just generally lack power? Have you checked thoroughly for boost leaks? Checked for a vacuum leak on that accordion shaped intake hose from the airbox to the turbo? Have you been filling up at the same gas station?
If you can read sensor data with your scanner, what does the coolant temp read at operating temp? What is your long/short term fuel trim? What does the MAF read at idle?
Old Jan 30, 2012 | 05:48 PM
not with this tool it it starts fine hot or cold somtimes it feels likes its going to die and cant boost past 5-6psi om my boost gauge it reads 20 when at idle i checked every dam line hose like 20 times. i only use shell vpower and use the same 2 stations most the time .it feels like its in limp mode this happen b4 when i was up im the mountains but the car reset back out of the limp mode thing
Old Jan 30, 2012 | 05:49 PM
I deleted my own post. I'm sorry to all who saw it including WagonPimp. I don't want to treat you the way you treat "us".
I'd like to think I'm a better person and the best I can do is hope you find someone to help you because as far as I'm concerned you're just a little too angry for me to care.
Old Jan 30, 2012 | 06:00 PM
What did the old spark plugs look like?
Your boost gauge reads 20 PSI at idle?
Old Jan 30, 2012 | 06:11 PM
You are just too nice ..... you still care
Old Jan 30, 2012 | 06:59 PM
Well, he didn't answer 1/2 of my questions so I guess he doesn't want my help either.
Old Jan 30, 2012 | 07:27 PM
i thought i got them all anyways sparkplugs didnt look to bad black but thats it boost gauge is at -20 .thanx for the help and to the people that think there cool go suck a fu ck ing d !~ ck
Old Jan 30, 2012 | 07:49 PM
Here are my UNANSWERED QUESTIONS:
1. What did you do as the "tune up"? Did you install new plugs? Did you install new wires? How old are your wires, they DO have a date on them? Did you replace the rotor? Did you do a new cap?
2. Are your brakes pulling? Have you jacked each wheel and see if the brakes are sticking? Are the parking brakes messed up and causing the rear tires to drag?
3. Did you scan for codes? ANSWERED
4. Do you have a fuel leak? ANSWERED
5. How are you measuring gas mileage? Using the car trip computer? Doing it manaually between fill ups? Have another method like ScanGauge II?
6. What do you consider "run like crap"? Is the idle smooth? Does it hesitate when you put your foot in it?
7. Did you READ the "How to improve gas mileage thread"? Well, did you?
8. What type of plugs did you install? OEM? AutoZone? NGK? Huh?
9. What are the current plugs gapped at? Did you check the gap before you tossed them in? Are they at .028?
Out of 10 questions you answered 2 and half answered 2. Do you know that you have ADD?
Old Jan 30, 2012 | 07:55 PM
i answerd them all but like 2 brakes dont pull checked them all plugs are 0.28 ngk plugs i told you wires and rotor and cap are like new i checked gas by my app on phone and you can see the gas gauge drop when i start to push the gas after a few miles it starts to drop
Old Jan 30, 2012 | 08:29 PM
What brand plugs did you install?
Old Jan 30, 2012 | 11:18 PM
  #17
ngk..
Old Apr 2, 2013 | 06:36 PM
  #18
mc2prod's Avatar
Sorry to dredge up an old painful thread. In case someone else has the same issue as the original poster. There is an altitude regulator that adjusts the fuel mix when in high altitudes. Crud can get into this altitude regulator and cause excessive fuel consumption. The Original Poster mentioned that he was driving off the "mountain". This is only a possibility for anyone else who may have the same issue. No need to reply.
wheelsup
Apr 16, 2017 08:47 PM
FourToes
Jun 22, 2015 02:47 AM
NHXC
Apr 29, 2010 09:33 AM
C70CoupeMaui
Feb 24, 2008 07:12 PM
