97 volvo will not go into drive
Old Mar 23, 2009 | 05:51 PM
shawnbrownpi's Avatar
Default 97 volvo will not go into drive
My wife has a 97 volvo 850 wagon. For some reason when you crank the car and go to put the car into gear the gear stick will not move. The ABS light comes on and everything in the car works but the car will not go into gear. So if anyone has any answers please help.
Old Mar 23, 2009 | 07:44 PM
Does the headlight not work either?
Old Mar 24, 2009 | 05:44 AM
JimKW's Avatar
Is the gear shift lever stuck in Park? If so there is a little button you can push to release the gear shift. If that does it you need to replace the mircroswitch down under the console.
Old Mar 24, 2009 | 07:45 AM
bestharry's Avatar
If you have following symptoms :
- Gear lever stuck in park
- ABS Tracs lights ON
- Head lights or Daytime running lights off
Then simply replace the electrical part of the ignition switch. To make sure, just wiggle the key little bit after starting the car and see if thinks look better.
freq
Apr 11, 2023 06:33 AM
lillymae
Feb 4, 2012 05:14 PM
volvoguy2323
Jul 6, 2010 02:59 AM
johnaca
Apr 15, 2010 11:19 PM
RHS
Jul 24, 2009 08:20 PM
