abs engages any thoughts
Old Jul 20, 2012 | 11:16 PM
dlaxdal's Avatar
Default abs engages any thoughts
My abs wants to come on without pressing the peddle. I had the fluid changed and the sensors cleaned and it still engages. Any help would be appreciated. My 850 turbo does not have the module that you solder. It has the plug in controller.
Old Jul 22, 2012 | 07:22 AM
I'm pretty sure that the Volvo system uses pressure from the pedal to operate. It doesn't have any type of resevior to save pressure and operate on it's own. I'm trying to figure out what it is that is happening in your system.
Is it that you hear it trying to modulate or pulse or is a wheel actually locking and releasing? What year do you have and do you have a check engine light at all ??
Old Jul 22, 2012 | 01:41 PM
dlaxdal's Avatar
I have a 1995 850 turbo. The abs kicks in and there are no fault codes to read. I pump is kicking in. I pull the fuse and wait a little and then put the fuse back in and it works fine for a while and then it will do ot again. I had the brake fluid changed and all the abs sensors were cleaned. Again there are no fault codes either.
Old Jul 22, 2012 | 03:22 PM
Vmax's Avatar
Does the car physically slow down when you hear the abs coming on? It could just be audibly checking itself right after you go faster than 15mph.
Old Jul 22, 2012 | 04:15 PM
dlaxdal's Avatar
Yes the ABS kicks in for some reason. Then I pull the fuse and it resets itself and you can drive normal. After a ahile the abs kicks in again. So my daughter has to drive with the fuse out for now
Old Jul 24, 2012 | 06:55 PM
MattyXXL's Avatar
Is the abs light on?
If so im betting module
Old Jul 25, 2012 | 06:32 PM
dlaxdal's Avatar
yes abs light is on
lukesvolvo
Oct 6, 2020 01:22 PM
irish_07
Jan 19, 2013 11:21 PM
Athilla
Aug 31, 2010 10:49 PM
PLCguy67
May 15, 2010 12:15 PM
HummerGuy
Jan 9, 2009 02:00 PM
