ABS Light
Old Jan 22, 2009 | 10:14 AM
lowbeer's Avatar
Default ABS Light
Hi,
I ahve a 97 850 with no traction control. From time to time the ABS light comes on and then after a while goes off. Any clues about what to do about that? Is it serious?
Thanks,
Nate
Old Jan 22, 2009 | 10:17 AM
1996850turbo's Avatar
Default RE: ABS Light
Have the codes pulled is the first place to start.
Old Jan 22, 2009 | 10:25 AM
Ozark Lee's Avatar
The ABS module is failing, it happens to nearly every one of them. There are several rebuilders and they will rebuild the unit for under $150.00. Google Volvo ABS module repair and a variety of rebuilders will pop up. If you know how to solder you can fix it yourself, a link to a writeup I did on that subject will pop up as well with that Google search.
When the light is on your ABS will not be functional but the brakes will continue to work. The problems will get worse and eventually your speedometer will quit working if you don't fix it.
...Lee
Old Jan 22, 2009 | 12:14 PM
JimKW's Avatar
Victor in California did mine. I am sure you can find his website with a search here. I don't have time to find it right now.
Old Jan 23, 2009 | 04:05 AM
JPN's Avatar
JPN
FYR:
http://home.earthlink.net/~vicrocha/
https://volvoforums.com/m_58856/tm.htm
JPN
nealeas
Mar 24, 2018 09:59 AM
Scott V
2001-2013 model year V70
Feb 8, 2014 06:46 PM
piv15
Nov 3, 2012 07:56 PM
paulh
Jan 30, 2008 08:22 PM
robohopar
Sep 27, 2007 11:37 AM
