ABS light came on 1995 850
Old Sep 3, 2011 | 08:31 PM
dlaxdal's Avatar
Default ABS light came on 1995 850
I finally cleared the check engine light and now the ABS light came on, any thoughts out there. I will try and clear that light also.
Old Sep 4, 2011 | 03:54 PM
There are lots of ABS write ups. Let me know if you need me to help you find one.
Old Sep 5, 2011 | 08:10 PM
If yours has an OBDII port above the shifter like mine does you can go to OReilly and borrow their scanner. They have one that does ABS and all you have to do is give them your license and use it in their lot. You can read the code, reset the light and then drive it and see if you set the code again.
Old Sep 6, 2011 | 09:18 AM
I don't think that a normal OBD-II scanner can reset that ABS or SRS light. You will likely have to go to a dealer or good indi shop for that.
Old Sep 7, 2011 | 02:59 PM
It will not do the SRS (air bag) light. That would be dealer or the 70.00 air bag only tool that IPD or Groton sells. OR, if you're lucky the diagnostic center under the hood will let you read and reset if yours has one.
I know that O'Reilly started to stock their stores with a check engine code reader that did ABS too.
BUT - - - - >
Diagnoses ABS codes on most 1996 and newer GM, Ford and Chrysler vehicles.
It's a cheap unit and doesn't do imports. I hadn't used it but that's a cut and paste from the tools ad. Sorry
Old Sep 7, 2011 | 03:18 PM
Ozark Lee's Avatar
On a '95 you can read the codes from port A-3 and then clear them. If the code comes back you will at least have a code or codes to post back so that we can point you in the right direction.
The '93 to '95 ABS units are not nearly as problematic as the later models.
...Lee
Old Sep 14, 2011 | 11:27 AM
Did you get around to reading the ABS code?
HelgaTheS80
Jan 4, 2017 12:16 PM
Dainos
Jun 8, 2016 12:36 PM
big_green_wagon
Jan 24, 2013 12:22 AM
