ABS light on, no headlights or turn signals
Old Oct 27, 2013 | 09:23 PM
xevo's Avatar
Default ABS light on, no headlights or turn signals
This has happened on two separate occasions and on each it was temporary. The ABS light stayed on yet I have no problem with the brakes. But the turn signals or headlights would not come on (I could still flash the high beams), and the shifter would not move out of Park (I had to push the Shifter Override button). Last time it happened, I stopped at a store to pick up something after driving it several miles, and when I returned to my car and restarted it, everything was normal. (Which was a good thing as it was getting dark.)
I wonder what could have caused that.
('95 850 N/A, automatic)
Old Oct 27, 2013 | 09:46 PM
97black850's Avatar
possible bad ignition switch?
Old Oct 31, 2013 | 12:03 AM
olyboy2010's Avatar
im having the same issues xevo, I have no turn signals, no headlights, none of my lighst on my dash such as trac, heated mirrors, and I have to override shift my car out of park?????
Old Oct 31, 2013 | 12:26 AM
awfulwaffle's Avatar
The ignition cylinder on my 850 is a tad loose. Sometimes after starting, I don't rotate it back far enough and the very thing you describe happens. If your ignition cylinder has a little bit of play, try rotating the key back a little bit and see if your lights come back.
Old Oct 31, 2013 | 09:51 AM
Old Nov 1, 2013 | 01:01 AM
What they said. My problem was an intermittent habit of dropping out of cruise and not engaging again. After a lot of reading and some playing with it found out it was the switch. Replaced and no further problems.
Old Nov 3, 2013 | 06:22 PM
olyboy2010's Avatar
that was the issue
no more problems
Old Dec 28, 2014 | 03:37 PM
Antho32's Avatar
. Thank you for this I just purchased 1994 850 wagon for 400 good condition besides doors don't open from inside but that's nothing. Anyways I was having problems with headlights blinkers and shift override to get out of park. All of that was fixed by simply turning the key back a little after ignition. Now to fix the minor oil leak from the cap
Old Dec 28, 2014 | 05:01 PM
You need to remember that if you need to "adjust" the switches position then it's wearing out and it's best to replace it while it's still working.
ijourneaux
Jan 5, 2014 05:38 PM
atb731b
Apr 11, 2013 08:48 AM
gdorio
Aug 19, 2011 10:20 AM
VDriver24093
Feb 21, 2011 04:35 PM
bpeabody
Aug 2, 2004 12:16 AM
