1996 850 turn signals/headlights/speedometer
Old Aug 18, 2011 | 02:56 PM
gdorio's Avatar
Question 1996 850 turn signals/headlights/speedometer
Hello.
Recently my 850 turbo station wagon, 1996 started to intermittently lose the turn signals, speedometer and headlights. I cannot use the signals, the speedometer sits at 0 and I cannot turn the headlights on. In some instances 10 minutes later all was fine. In some instances I would park the car and still not have the any of them working. I also have a similar problem with my gear shift when I start up. Sometimes I need to press the override button to shift the gear. Once done it works fine. Sometimes it shifts fine w/o doing the override. Don't know if these are related.
Thank for any help on this,
George
Old Aug 18, 2011 | 05:00 PM
gdorio's Avatar
Default Solution to 850
After leaving this message I came across a similar thread and the solution was to turn the ignition passed position III. In my case was to hold it there for a second two and all is working now. Advice from that post suggested that I need to replace the ignition switch.
Old Aug 19, 2011 | 10:20 AM
MattyXXL's Avatar
Yes it is your ignition switch.
You can go either IPD or FCP.
I would go with FCP cause your in NY they are in CT and you will get it next day.
Here You Go--->Volvo Ignition Switch (850 940 960 760) Genuine Volvo 9447803 | FCPEuro.com
xevo
Dec 28, 2014 05:01 PM
spidersilva
Jan 8, 2012 09:06 PM
VDriver24093
Feb 21, 2011 04:35 PM
rama71
Jul 30, 2008 07:54 PM
autolampsplus
Dec 18, 2006 01:42 PM
