AC blower is blowing while switch is in off position
Old Sep 26, 2011 | 04:26 PM
Dainos's Avatar
Default AC blower is blowing while switch is in off position
Any idea what could be the cause of this? I have a 95 850 turbo
Old Sep 26, 2011 | 05:46 PM
MattyXXL's Avatar
ECC or MCC?
Is your switch on 0 or auto?
when its on do you have a variation of speeds when you move the slider?
Could be a bad resistor but we need more info on the problem..
Old Sep 26, 2011 | 05:57 PM
Do you have the automatic climate control or the manual?
I know in doing some research that your symptoms sound a lot like it's the blower motor resistor but it's been a while since I was in those posts.
Old Sep 26, 2011 | 06:00 PM
Old Sep 26, 2011 | 06:08 PM
Dainos's Avatar
I will check the links provided.The blowing speed is constant (at the highest) and the the compressor is not coming on if I turn the ac on.Also, the orange light which indicates the ac being off isn't coming on either
Old Sep 26, 2011 | 07:27 PM
MattyXXL's Avatar
Sounds like a resistor
Old Sep 26, 2011 | 08:26 PM
Dainos's Avatar
Is there more than one resistor for the blower?
Old Sep 26, 2011 | 10:39 PM
That light might just be a burnt out indicator but shouldn't have anything to do with your problem.
There is only one resistor but there is a completely different blower motor resistor for the ECC from the MCC. You need to find out which you have. Do you actually set it to a temperature by number or just turn the dial to increase or decrease the output?
gentlejax2
Apr 15, 2013 08:58 AM
Memuns
Dec 29, 2011 06:44 PM
VolvoLover2011
Jun 7, 2011 03:32 PM
thumper56
Nov 4, 2009 08:34 AM
