AC Compressor not starting
I now have my first 850 model. but have owned 740 and 240 models in the past. My AC compressor
does not start, I have jumpered the switch on the low pressure line near the firewall with no luck.
I would really appreciate any thoughts from forum members from where to check now. Relays?
Any other wires to jumper? I have replaced the condenser so there is no refrigerant in the system at all
ChuckM
95 850
98 Cross Country
ChuckM
95 850
98 Cross Country
Jumping the low pressure switch should turn the compressor on whether or not it has Freon. (Not reccomended without freon though)
Make sure when you jump it you get power to the compressor.
the low pressure sensor is on the ac line that runs from the firewall back into the compressor.
trace the line from the firewall - as I recall you'll see it over by the overflow container. pull off the connector and you can jumper with a paper clip.
You might check and make sure you have voltage at the low pressure switch on one leg and check the wiring diagram to see where the other leg should go to see if the voltage is getting there. I have jumped the wires right at the compressor to make sure the compressor turns on there but don't do it for long if the system is dry.
rideagiant
Sep 10, 2009 07:56 AM
branse
Aug 16, 2006 08:49 PM
