'After blower' a/c system questions
Old Nov 7, 2008 | 08:22 PM
ShaginWagon's Avatar
Default 'After blower' a/c system questions
I remember reading somewhere that to combat the condensation from corroding the a/c core, volvo brought out an 'after blower' mod.
It ran the blower fan for a period of time after the car was turned off to dry off the core.
Don't spose anyone has more or detailed info on this ?
Taaaaa
Old Nov 7, 2008 | 08:40 PM
Default RE: 'After blower' a/c system questions
That is true but there is a wiring kit that needs to be installed to make it all work.
Old Nov 7, 2008 | 08:49 PM
I am capable of making my own looms/conections etc.
So what I'm after is just what it did and when.
More the theory of operation if you will.
I'm thinking of putting in a timer that runs the blower for x minutes after the car is turned of if the a/c has been used.
Old Nov 7, 2008 | 09:37 PM
It is set up to come on within 50 minutes of the car being turned off and it runs between 5 to 10 minutes then turns back off.
Old Nov 7, 2008 | 10:10 PM
Excellent. many thanks.
Don't spose you have any other info on it.
Just trying to understand the reason behind the time frames.
I can reason that it waits before turning on because it will take a bit before maximum condensation occurs.
And this would be related to temp/use/humidity.
And obviously takes anything up to 10 minutes to dry the core.
Old Nov 8, 2008 | 06:02 AM
Not right off hand but I will see what I can dig up in the next couple of days.
Old Nov 8, 2008 | 04:14 PM
Default something
As a girl at work says, 'Man you are The Bomb'
Old Nov 9, 2008 | 06:56 AM
Default RE: something
LOL
Phil 850
Jul 25, 2012 10:01 PM
btelzer
Jun 12, 2011 08:30 PM
jmallie
Sep 17, 2009 09:47 AM
kupiec79
Oct 19, 2007 12:54 AM
