Air cleaner hose connections
Old Sep 3, 2013 | 08:02 PM
Yvonne Coyle's Avatar
Default Air cleaner hose connections
I was changing the air filter tonight and broke a cap that covered a nipple on the back side of the air cleaner housing. I also noticed a hose with elbow that looks as if it should be attached there as well. 1997 850 base.
Old Sep 3, 2013 | 08:11 PM
Default More photos
Photo of back of air cleaner showing two nipples and white hose with elbow.
Old Sep 3, 2013 | 09:08 PM
1995Volvo850's Avatar
That's too bad. Hope you get it sorted out.
Old Sep 3, 2013 | 11:16 PM
97-850Wagen's Avatar
The white hose with the rubber connector runs to the bottom nipple iirc (will have to double check in the morning). As far as the small cap that broke, my car is missing the same piece from (IIRC) the top nipple and runs just fine without it. If you are worried about it, take a small piece of vac line that fits on the nipple and stick a screw into it, then put it on the nipple (cheap and functional fix lol) or pick up a new cap. As far as the white hose, I believe it has something to do with your PCV or emissions bits. Mine was replaced by the former owner when I bought the car, so I'm not 100% certain since I haven't had a reason to look into it yet
Old Sep 4, 2013 | 08:40 PM
Thanks I put the rubber connector on the bottom nipple and will try and get a cap for the top . I drove the car tonight and it seemed fine. I am getting ready to move to Atlanta and will have to pass emissions so I am trying to create best conditions on the car on the cheap hence the air filter change. I have 228,000 on it and hope to put 238,857 on it at least so I can say it went to the moon thanks again 97 850 wagon.
f88
Mar 25, 2011 06:37 AM
rvinson2
Jul 27, 2009 09:21 PM
ElJefe91
Nov 18, 2008 04:14 PM
chrispk313
Mar 17, 2008 07:24 PM
reg
Jan 1, 2006 11:41 PM
