Air Pump operation
Old Dec 22, 2006 | 04:47 PM
Shartzy4's Avatar
Default Air Pump operation
On a 1996 850 should the air pump always run? Or does it just run during cold start-up and when control valve is activated?
Thanks
Old Dec 22, 2006 | 07:19 PM
Default RE: Air Pump operation
It is only supposed to run after COLD start up and it will run for anywhere from 30 seconds to 1.5 minutes.
If it keeps running all the time check the Relay for water in the relay.
Old Sep 26, 2012 | 10:16 AM
benmtho's Avatar
Default Air Pump Relay LOCATION
I'm looking for the location of the Secondary Air Pump RELAY so i can inspect it.
Does anyone know where this bugger is located?
thanks,
Ben
Old Sep 26, 2012 | 10:28 AM
Brick850's Avatar
According to the wiring diagrams for the 850 there isnt a secondary air pump relay.
However I have found a vague reference to one which points to either above, or in front of the radiator on the left hand side.
turboxr
Dec 17, 2011 12:35 AM
4bnbad
Dec 28, 2010 05:47 PM
mewalsh100
Jan 6, 2007 12:20 PM
VBsportbiker
Aug 30, 2006 12:34 AM
summervi
Aug 28, 2005 11:14 AM
