Another Volvo hard start scenario
Old Feb 8, 2018 | 08:50 PM
garlendrix's Avatar
Default Another Volvo hard start scenario
So I’ve been lurking in the shadows for a while trying to use the forum to help me figure out what’s going on with my car but I’m stumped.
I just got my 96 850 turbo back on the road and now it’s having problems starting. It will crank no problem but takes a few trys to finally get it to turn over. Sometimes it can take a few minutes to start. Once it’s running, it runs like a champ. Turn it off and it takes forever to start again.
This is a list of things if changed/ checked:
no cel, no codes
compression ok
fuel pressure ok
batt ok
new coolant temp sensor
cam position sensor
crank sensor
idle air control valve
new fuel pump relay
new fuel pump
rebuilt injectors
fuel pressure regulator
fuel injector relay
different ecm
and I’m sure I’m forgetting to mention something...
I have no idea where tho go from here. Any help would be greatly appreciated
Old Feb 8, 2018 | 09:16 PM
firebirdparts's Avatar
Cranking is the point at which the air flow would read the lowest. Vacuum leaks would make more of an error. That might be one possibility. it's a long way from the MAF to the throttle on a turbo. Lots of plumbing.
Old Feb 9, 2018 | 01:38 AM
TnBob's Avatar
Make sure all the check valves from the tank forward are working.
Old Feb 9, 2018 | 08:53 AM
garlendrix's Avatar
so I heard that the earlier 850s had inline check valves but the later ones were built into the fuel pump. How many other check valves are there?
Old Feb 9, 2018 | 12:47 PM
TnBob's Avatar
You could pinch off the return line temporarily to see if it's the regulator or check valve (s), number I dont know
amazon2
May 26, 2014 04:01 PM
tdrendel
Nov 4, 2012 07:14 PM
donf
Jul 4, 2012 08:47 PM
96960Chris
Jun 25, 2011 04:49 PM
trooperone
Sep 24, 2009 10:08 PM
