Attaching Instrument Cluster to Dashboard
Old Jul 15, 2010 | 12:45 PM
  #21
gilber33's Avatar
Originally Posted by TacklaNHL
Anyone know any "how-to's" out there for ENTIRE DASH REMOVAL??
Did you click the link I gave you??
First link that pops up on a google search:
http://woodjoiner.com/volvo/
Old Jul 15, 2010 | 02:48 PM
  #22
TacklaNHL's Avatar
Thanks. I did see that link, but the 1st time it was taking so long to load I moved on to a task here at work and then forgot to look at it.
It is good. No sweat. But... i've got an in-dash GPS unit where the factory radio is... now i'm worried that i'll have to mess with that. And that's something I don't want to do. I know nothing when it comes to electronics, wires, voltage, and all the electronics terms involved... I really don't want to mess with that.
AHHH!! This is all from these stupid plastic bars. DAMNIT! There's got to be some sort of creative fix for this. I especially don't really want to pull all this at a junk yard and then again at home (i'll have to find a friend's garage or driveway for this).
I guess i'll go to a junkyard this weekend and see if I can even find one the same color.
Old Jul 15, 2010 | 02:51 PM
  #23
TacklaNHL's Avatar
Well, I guess with the GPS unit... it's got to have plugs and connectors that go into the back of it, as long as I just pull those out and keep them all together (zip ties for instance) I should have any problem pulling it and then putting it back in.
I'm freaking myself out because this is such a huge job.
Old Jul 15, 2010 | 03:06 PM
  #24
ibified's Avatar
Tackla: where are you located? perhaps someone here can help you out.
Old Jul 15, 2010 | 05:23 PM
  #25
TacklaNHL's Avatar
Oh that's a great idea!
I'm in Denver, CO (is there any other?). I would love to find a fellow Volvo-nut-job. Would love to help someone with projects... cause then I learn to do them on mine (and vice-versa).
Old Jul 15, 2010 | 05:25 PM
  #26
TacklaNHL's Avatar
I gotta post a photo of my in-dash GPD unit... you guys would love it. Fits so well in the factory radio slot.
Old Jul 15, 2010 | 05:39 PM
  #27
ibified's Avatar
Sweet. Sorry I'm not closer - I'd be glad to help you out on your projects. Hopefully someone else can chime in that can help you out. Look forward to seeing that GPS. If you put your GPS in the radio slot though, where did you install the radio?
Old Jul 20, 2010 | 12:33 PM
  #28
TacklaNHL's Avatar
The GPS unit has an FM/AM radio, CD player, iPod connection (I ran through to the glovebox), subwoofer/amp connection, and even a rear camera connector (though I haven't done that).
Kept my factory cassette radio... in case I were to ever sell the Volvo. But with 220K miles on it, I doubt it (though the engine was replaced and has about 85K on it).
Old Jul 31, 2010 | 05:27 PM
  #29
TacklaNHL's Avatar
GOT IT FIXED!
Used the Dremel to cut the little posts off junkyard dash (that was torn to hell anyway)... and then actually, the way I did attached them on my car... I cut off the same length off the broken knubs that were left over from the cluster attachment bars (used a steak-knife as the Dremel wouldn't get in there well-enough)... and then cleaned it all up, made sure it was a "glue-able" contact, and then I actually clips the brackets to the clips and then glued them in place (that way I wouldn't have to cliup them after gluing) used DevCon 5-min epoxy. Perfect fix.
So glad to be done with that rattle and spared myself the time of removing the dash.
Old Jul 31, 2010 | 08:22 PM
  #30
vpatrol's Avatar
reading this thread got me slightly curious. I'm not sure what the brackets look like that everyone is talking about but could you not screw it instead of epoxy or JB-Weld? Whatever you are screwing into (plastic I'm assuming) get some meat behind it like the block of wood mentioned earlier. Should make it more weight bearing. Unless the screw is going to be exposed or the shape of the bracket won't allow it of course. Just throwing it out there.
Old Jul 31, 2010 | 11:59 PM
  #31
TacklaNHL's Avatar
Yea, no way to do that really... the backside would be your "visual" area in front of the face of the instrument cluster itself.
Old Aug 1, 2010 | 02:53 AM
  #32
vpatrol's Avatar
I see. I assumed the bracket was mounting to the car and not the dash however re-reading the posts, it makes sense now.
Old Aug 1, 2010 | 01:11 PM
  #33
Rosew6211's Avatar
If you have the room, it's amazing what you can secure with small tie wire and a small but stiff spring to hold tension; however I don't recall the amount of room I had to try this and it would probably invove drilling and using self tapping screws to secure wire ends. I've never had luck with eithe epoxy or crazy glue jel holding anything togather when it's in tension
volvo5volvo
May 29, 2012 05:46 AM
j70wtc
Nov 27, 2009 01:00 PM
hubmachine
Jul 16, 2006 08:25 PM
cool_kyle_3000
Mar 5, 2006 11:29 PM
oalsa
Nov 16, 2005 11:12 PM
