Audio help
Old Dec 7, 2007 | 06:47 PM
Stornoway's Avatar
Default Audio help
I removed the audio in my 96 850 to fix a loose radio antenna but did not have the code to set it up when I reinstalled it. I went to the local VOLVO agency who got me the code but it wouldn't work. Thinking it was a replacement system theyused the data from the audio systembut could come up with nothing else.Once I had entered the incorrect code 3 times it locked me out permanently (not just for 2 hours per the handbook)and now just displays OFF. The system works perfectly but I cannot unlock the anti-theft code. Any suggestions or help would be immensely appreciated.
Thanks Tim
Old Dec 7, 2007 | 06:57 PM
yert315's Avatar
Default RE: Audio help
Get a new deck! You can get a newone for $100 at best buy or circuit city. Thats what I would do
Old Dec 7, 2007 | 07:09 PM
wallie's Avatar
You might be able to get it working this way... http://au.geocities.com/ozbrick850/radio-codes.html
I've never tried it so I can't vouch for it myself but it seems to have worked for this person. Did you try giving the dealer your vin # for them to look up the code. You might have said it might not have been the original HU, I'd have to re-read, good luck.
Old Dec 7, 2007 | 07:26 PM
Stornoway's Avatar
Mine has the CD player as well as the cassette so I'm not sure the code encryptor would work. It's worth a try to save $100. I did give the dealer the VIN as well as the serial and model # fromthe audio unit. They gave me a 4 digit code but it wouldn't work. I'll let you know if the encryptor thingworks.
Old Dec 8, 2007 | 12:29 PM
green850's Avatar
yeah i would just get a new head unit, same thing happend to mine
i just went out and bought a new one for about 100$
funny thing is, after that i went on to spend another 800$ on my system hah, it gets addicting
Old Dec 8, 2007 | 08:15 PM
Stornoway's Avatar
A simple solution. Itracked downthe previous owner and asked her if she knew the audio code. She said she'dhad trouble with it and finally found the correct one at trhe Volvo dealer and written in the Owner's book where I found it inside the front cover. It was completely different from the one given me by the same Volvo dealer using the same VIN.
dsuk
Jul 14, 2009 01:07 AM
pilot_alex_14
Mar 12, 2008 09:54 PM
Uhills
Feb 16, 2008 08:08 AM
240ttn23
Dec 16, 2007 09:53 AM
cracker_j
Jun 11, 2006 04:19 AM
