Auto climate control problems
Old Feb 8, 2011 | 03:31 PM
goober91101's Avatar
Default Auto climate control problems
The fan speed control stopped working the other day, just blows on hi till you turn the key off and it will only blow cold air out the dash vents, so I figured its time for a new control. Before buying a new one I took off the covers and found a burnt spot on the main board. Fixed that and all was good for a week. Now I have no defrost and only cold air on the drivers side... Anyone have any info on repairing these things, or is Ebay my next best option?
Old Feb 9, 2011 | 05:19 AM
Its Chey's Avatar
I really can't answer your question with any validity however, ebay isn't your only source. In my for sale thread I have an ECC and resistor. This of course is an option if one of these turns out to be the problem.
Old Feb 9, 2011 | 06:21 AM
Henry10's Avatar
Do the "Recirc" and "A/C Off" lights flash when you start the car? If they don't flash, it might just need damper motor adjustments / resetting.
I am assuming that when you soldered the board, you did not melt too much solder to connect it to adjacent circuit lines.
Old Feb 9, 2011 | 12:01 PM
vjaneczko's Avatar
Does it still blow only on High? If so, you'll probably need a new Power Stage (for an ECC) or resistor (for an MCC).
As for the cold air, it sounds like the damper motors are not doing their thing.
Is there any heat anywhere at anytime? If not, you'll want to check your heater core to make sure it's OK.
bond007
Jan 27, 2011 03:49 PM
Touristica
Feb 11, 2010 05:59 AM
arls116
Oct 3, 2008 07:18 PM
Greg G
Nov 10, 2007 05:06 PM
parkerjensen
Jul 5, 2007 04:46 AM
