Automatic transmission jerk in reverse
Just purchased an 850 with 126K miles. Great car, in the past i've had an 240 turbo with a 290K miles and still run strong.
I have a question that is above my mechanical skills. Transmission when put in reverse has a jerk. when i hold break/clutch and add a little bit of gas it kicks in, but it is a jerk. "I THINK" it also kicks in if i JIGGLE the shifter, but it might be extended time or my foot adding gas on pedal. Also I can feel minimal jerk then going from 5 to 4 th gear on the highway, but this one is not significant.
Fluid has a darker brown color to it, but i bet it was not changed in years.
Otherwise trans shifts perfectly.
IS THERE an external adjustment for reverse linkage, or some kind of sensors/ computer that i can look into before worrying about trans?
thank you everyone. Bartok
http://www.rx7club.com/showthread.php?t=800210
http://www.rx7club.com/showthread.php?t=801903
for your enjoyment samples of my posts from different forums.
wheelsup
Dec 24, 2008 06:20 PM
