BAD BRAKE FLUID LEAK
Old Jun 26, 2008 | 06:37 AM
griffo33's Avatar
Default BAD BRAKE FLUID LEAK
I have a very bad leak but cant figure out exactly what the part is it is coming from or how to fix it. If you follow the brake lines off from the proportioning valve they go down to another "block" it has all four lines in a row right below them is a black box looking thing not sure if they are attached to this though. The black box or cover has 2 holes in the bottom of it / acess to what feels like torx screws. This is where it is all coming out at. Any help is appreciated I really need to fix this. I hope someone knows what area im talking about
Cheers
Jimmy
Old Jun 26, 2008 | 07:50 AM
Ozark Lee's Avatar
Default RE: BAD BRAKE FLUID LEAK
What you describe is your ABS system. The ABS controller modules all seem to go bad but your problem with it leaking is fairly rare. I would check with your local salvage yards for a replacement. You will obviously need to bleed the brakes after you change it. There are two base versions - pre '95 and '96 and on - they look very different and you should be able to tell if you have the correct style by just looking at it. What you cannot tell just by looking at it is if it has TRACS or not - you will need to get a unit that matches your original in that regard.
...Lee
Old Jun 26, 2008 | 08:39 AM
Psaboic's Avatar
+1. But I have never heard of one leaking like that. Are all the lines tight at the black ABS controller?
Old Jun 26, 2008 | 09:37 AM
griffo33's Avatar
Yeah I think so, I haven't had time to get parts off to have a close look, thats tomorrows job. The leak doesn't seem to be coming from the lines though.
Old Jun 26, 2008 | 07:13 PM
That is strange. Also look on the back of the master cylinder and see if there is a sensor coming off the back of it. If it has one make sure the leak isn't from that.
Sacramoni
Aug 25, 2015 02:36 PM
bryan13
Jul 1, 2008 12:05 PM
myspv
Oct 29, 2006 11:29 PM
my850turbo
Jun 27, 2006 01:29 AM
