Bad Left Side Heater
Old Nov 8, 2007 | 10:17 PM
volvoownerct's Avatar
Default Bad Left Side Heater
I have a 1995 850 GLT. I replaced the heater resister and the blower works fine. However, I only get heat on the right side. The left side always blows cold air. Any ideas on what's wrong?
Old Nov 9, 2007 | 06:30 PM
Default RE: Bad Left Side Heater
Is it ECC or MCC
ECC electronic climate control. Do you have AUT on the fan and temp controls?
MCC Manual climate control just has colors for the temp settings.
Old Nov 9, 2007 | 09:10 PM
It is MCC.
Old Nov 9, 2007 | 09:29 PM
Has anyone had the dash out?
Old Nov 10, 2007 | 12:39 AM
I took the glove compartment out a few months ago to replace the resister. Otherwise, I don't know of any of the rest of the dash being out.
Old Nov 10, 2007 | 08:36 AM
There is a cable from the **** to the climate box.
If you remove the drivers side lower dash panel and look up you should see the cable.
Move the **** and watch the cable. I would say either the cable slipped or the panel where the **** is broke.
Old Nov 10, 2007 | 08:47 AM
Psaboic's Avatar
Take Tech's advice. I had a different model car that had the same problem a few years ago and it was a slipping damper door cable.
Good luck
wjwolfe82
Mar 19, 2015 10:21 AM
HP Sauce
Mar 7, 2009 07:49 PM
nicolaselias
Feb 28, 2008 08:23 PM
drum
Aug 13, 2007 10:08 PM
