Ball Joint
Old Mar 3, 2010 | 11:14 AM
svspeeder's Avatar
Default Ball Joint
I have a 850 turbo. My ball joint is the whole assembly. I have to change it for the 2 nd time due to the pot holes. Can I drill out the permanent ball joint and put in the ball joint with the bolts instead of changing the whole assembly? I guest what i am trying to say is there are 2 type of ball joint, used on these cars, one that you can chang the ball joint itself and the other is the type you have to chang the whole control arm.
Old Mar 3, 2010 | 11:36 AM
JimKW's Avatar
Probably end up spending more than by buying the whole assembly. I just bought mine from Darrell Waltrip Volvo for about $110 per side.
dpvovo
Feb 18, 2019 07:41 PM
JPN
Sep 10, 2006 03:05 AM
med01e
May 23, 2006 12:41 AM
volvobacon
Oct 11, 2005 09:11 PM
indagutter
Oct 11, 2004 07:10 PM
