BALL JOINT TORQUE
Old Jul 26, 2008 | 05:10 PM
sheriffjohn's Avatar
Default BALL JOINT TORQUE
WILL SOMEONE PLEASE TELL ME THE TORQUE SPECS FOR AN 850 CONTROL ARM INCLUDING THE BOLT THAT HOLDS THE BALL JOINT IN PLACE CAR IS A 95.CHILTON SAYS 15 LBS AND NOTHING ABOUT ANGLE TORQUE.THANK YOU TO MUCH
Old Jul 26, 2008 | 06:02 PM
autoxray's Avatar
Default RE: BALL JOINT TORQUE
Control Arm Ball Joint Clamp bot nut = 37foot lbs
Control Arm to subframe = 51 lbs plus stage two is tighten an additional 120 degrees
dpvovo
Feb 18, 2019 07:41 PM
danielp
Mar 7, 2014 09:12 AM
med01e
May 23, 2006 12:41 AM
volvobacon
Oct 11, 2005 09:11 PM
indagutter
Oct 11, 2004 07:10 PM
