Battery draining over night
Hi guys, I put a new battery in my 96 850 Turbo within the last 8 months. It's been fine until yesterday when I go to start the car and the battery is nearly dead. Nothing was left on, of this I'm sure.
Put her on the smartcharger for the day and she starts strong. Didn't drive it in the last 24 hours, go to start this eve and she's nearly dead again.
Terminal connections are solid.
What can I check? I have a meter if that will tell me anything.
Thanks for your suggestions.
Your glove box light most likely. Over time it seems to warp outward at the handle part of the door. What I did was cut a little square piece of those pads that goes under furnitures that prevent them from scratching floors to help close that gap to push on that switch to turn it off when the glove box door is closed.
boxpin did a nice writeup awhile back; here's the link
https://volvoforums.com/forum/volvo-...g-101-a-42655/
And like MC92 said, i would ck the glove box light first.
I have recently had the same problem, something was draining my battery, alarm worked ok, so was scratching my head to the cause, until i read this thread. Same thing here, glovebox light stayed on, checked battery with a multi-meter and sure enough was losing volts, not at a drastic rate but as i dont use my t5 that much, enough to drain the battery after a week or so, so i removed the glove box lightbulb, started the engine to get a full charge and again checked the battery after an hour, no drain. Also fixed my rattling glove box door in the process (probably the overall cause as it wasnt closing properly, Thankyou very much for the excellent advice.
Its a bayonet fitting. Yeah the arms on glove box lid are tricky to get out, you have to slide a thin flat ended screwdriver into the tiny gap and press outwards (towards the arm) really hard to explain and just as hard to do, but can be done. making the whole glove box insert easy to pull out revealing that pesky little bulb, mine was really rusty and almost welded in so took a pair of pliers too. Best of luck.
Thanks, Speagle, that helps to know so that I don't break more things. Again, like many of the release "buttons", it's counter-intuitive, since the space for the screwdriver is on the side you're supposed to push towards (the arm side). I'll try it. Right now I have four of those felt things that's barely keeping the light out.
silver260
05-29-2008 03:27 PM
