blower only works at max speed....help!
Old Jan 10, 2010 | 04:11 PM
timwu12's Avatar
Default blower only works at max speed....help!
so i changed out my blower motor bc it started squeeking and people said it's on its way out so i replaced it, however, now the fan only works when i set the fan speed to the highest possible (speed 4), the first three speeds don't work...does this mean the blower resistor needs to be replaced now too? And if i do need to replace it, where is it located? I can see what the part looks like on fcp's site, but when i was replacin the blower, i didn't see anything that resembled a connector piece with a whole bunch of heat sink fins on it.
Old Jan 10, 2010 | 05:27 PM
kelsodatrini's Avatar
Most likely resistor as if it only works on high speed it is no longer resisting current and just operating at a constant power constant "fast" speed.
I would for sure replace that, Your resistor is the giant heat sink looking silver module that will plug in on the actual blower motor.
The other is the power connector with two connections that clips to the housing and the 850 vehicle connector clips into it.
resistor:
ww2.justanswer.com/uploads/Joecamel90/2009-01-15_200157_Volvo_850_blower_resistor.gif
or google volvo 850 resistor in images and its a blakc and white diagram of the behind the glove box.
Old Jan 10, 2010 | 05:39 PM
timwu12's Avatar
in the link you sent, is the resistor H4 or H2?
and thanks for the help!
Old Jan 11, 2010 | 03:10 PM
timwu12's Avatar
btw, how can i tell if my car has automatic climate control or not? I mean i have that **** that has the "0-thick red rectangular bars" dial thing....so does that mean i have automatic climate control?
Old Jan 11, 2010 | 06:40 PM
Carrots's Avatar
Your car has manual climate control... if it had automatic, the fan switch wouldn't be labeled "0-1-2-3-4" And, on that note, the blower motor resistor on manual climate models doesn't have a heat sink. It'll be a black plastic pentagon- shaped piece, mounted to the left of the blower motor, accessible from behind the glove box, with a pigtail plugged into it.
blackbrick
2001-2013 model year V70
Aug 14, 2014 07:11 PM
louiebay
Apr 26, 2013 05:40 PM
nsblues
Jul 4, 2011 08:36 PM
Royalty
Aug 31, 2009 09:56 PM
