Boost Leak?
Old Jun 12, 2007 | 10:05 PM
rcarlborg's Avatar
Default Boost Leak?
I have a 96 850 Turbo Wagon. During acceleration I can hear a loud "Whooshing" sound when the Turbo starts to boost. It's not a whine or normal turbo sound. It's a whoosh. (Purse your lips together as if you're going to whistle, and blow without making the actual whistle sound. That's the sound) I know, I know... My description is retarded, but I'm trying....It only happens while the turbo is producing boost. The boost needle climbs to halfway (12 o'clock) and then goes about one needle width into the white. I have replaced the BCS and the three vacuum lines coming from it. Any opinions? I have tried to check all of the major hoses into and out of the intercooler and could not find any leaks.....What is it??
Old Jun 14, 2007 | 05:31 PM
Default RE: Boost Leak?
Maybe one of the hoses are collapsing under boost.
Old Jun 17, 2007 | 08:12 AM
B1mmer's Avatar
You've got a boost leak for sure. With that description, I would take a close look at the throttle body hose. It's very common to get large cracks in this area over time, giving you little or no boost. - AB
Old Aug 16, 2007 | 09:02 AM
TurboDave's Avatar
I would love to see if rcarlborg solved his problem, as I have the same symptoms, without the whoosh.
I've checked all my vacuum lines, checked the bcu, checked the turbine fan actually spins freely, with minimal thrust or side to side play. No smoke, no bad turbo whirly noises. Just no boost. I was hoping to find the waste gate stuck in the open position, but thats not my luck.
Old Aug 16, 2007 | 10:20 AM
JPN's Avatar
JPN
Hi,
As others have suggested, do a good visual inspection. You never know, it could be as simple as loose/missing hose/pipe clamps.
Good luck,
JPN
Old Aug 16, 2007 | 07:08 PM
Make sure the hose at the top of the intercooler isn't sucking shut under boost.
MurderedT5R
Jun 24, 2015 12:53 AM
turbo940v
Sep 3, 2010 08:36 AM
endneu913
Mar 28, 2010 11:41 PM
mygreenbomb
Feb 29, 2008 06:09 PM
blkwgnt5r
Mar 10, 2005 01:18 PM
