Rear spring removal on a '98?
Old Dec 31, 2006 | 04:32 PM
blackstarpower's Avatar
Default Rear spring removal on a '98?
Does anyone have a write up or can point me to a direction on how to remove the rear springs for '98 XC?
I've only changed the coil over type style like in the fronts. Do I need to compress the spring with a compressor while it is on the car, or does it drop out somehow?
THANKS
Old Dec 31, 2006 | 09:19 PM
Default RE: Rear spring removal on a '98?
I believe it should drop out as one unit then you compress once it is out of the car.
paul1149
Sep 6, 2012 11:20 AM
ludeless
Oct 30, 2011 07:02 PM
vjaneczko
Aug 16, 2010 12:01 AM
blackstarpower
Jan 5, 2007 12:26 AM
moet32
May 1, 2005 01:55 AM
