brake switch adjustment
Old Dec 24, 2011 | 01:41 PM
slowtype's Avatar
Default brake switch adjustment
I removed my brake switch while trying to diagnose the cruise control.
It is the adjusting brake switch, and when it was out I adjusted it all the way, so now it will not fit. How do I release the adjustment?
Old Dec 24, 2011 | 03:19 PM
slowtype's Avatar
Figured it out. Brute force. If you push on the part of the switch that comes in contact with the brake pedal it will adjust the switch length the opposite way.
Old Dec 24, 2011 | 08:47 PM
MattyXXL's Avatar
The brake light switch does nothing with the cruise control... if you look above the brake switch you will see the white cruise control switch..
Old Dec 24, 2011 | 08:56 PM
What model car do you have and what is going on with your cruise?
Old Dec 24, 2011 | 09:25 PM
Brake light switch vs. cruise control cut out switch.
http://www.matthewsvolvosite.com/95-...f-failure.html
FCP has the part if that's what's wrong.
1993-1997 Volvo 850 Cruise Control Cut Out Switch
Attached Thumbnails brake switch adjustment-brake-light-switch.jpg   brake switch adjustment-cruise-control-cut-out-switch.jpg
Old Dec 25, 2011 | 05:15 PM
slowtype's Avatar
Hi,
I pulled this switch because it was in my way when testing the other switch.
Which tested good with the ohm meter.
Cruise control does not work. I have the volvo manual for diagnosing it, but its difficult for me to understand. Cruise never worked since I bought the car. It doesn't even try to engage. I was going to test the control switch next.
95 850 wagon n/a.
Old Dec 25, 2011 | 07:57 PM
Did you read the thread in the DIY stickey?
Old Dec 25, 2011 | 11:16 PM
slowtype's Avatar
I started too. Seemed like it was geared towards turbo cars. That is why I checked the brake switch though.
Old Dec 26, 2011 | 10:00 AM
Well, they are not really different. The only thing about the turbo cars is that there is a boost gauge line that runs with the cruise line so if both fail it's easier to track down the difference.
Try this:
1. Check the linkage at the gas pedal, mine was loose.
2. Adjust the switch at the brake pedal.
3. Check the vacuum tubes that run off the cruise.
4. Check/change the cruise relay at the fuse box (under the lid).
5. Check the switch at the turn signal stalk.
6. Swap the cruise unit out under the battery tray.
Hope you get it working.
Old Jan 2, 2012 | 02:08 PM
slowtype's Avatar
So I didn't get around to anymore diag.
But it worked today. The first time I used it the car dropped about 10 mph before it kicked in. But each time I used it the system improves.
nextproject
Nov 16, 2009 07:04 PM
rspi
Jun 30, 2009 09:51 PM
unclerichiezjr
Mar 17, 2009 07:38 PM
Alanbw
Oct 21, 2007 07:30 AM
dinopix
May 9, 2006 08:10 PM
