S80 Brake Adjustment Question
Old May 5, 2006 | 03:20 PM
dinopix's Avatar
Default S80 Brake Adjustment Question
Are there any adjustments that can be made on 1999 S80 brakes? I just had new pads and rotors put on and it seems like there's no clearance and the pads are rubbing. Mechanic thinks he is just going to have to shave the pads down a bit. They are Brembo rotors, but I don't remember the brand of the pads.
Old May 5, 2006 | 08:56 PM
Default RE: S80 Brake Adjustment Question
There is no way to adjust them.
Are you sure they are the right parts?
Old May 9, 2006 | 02:54 PM
dinopix's Avatar
Parts were correct. The mechanic had to flush the brake fluid. Now they work fine. He showed me the fluid that he originally drained out when he did the brakes and it was very dirty. I don't know why he didn't recommend flushing the fuid to begin with, when he saw how dirty it was and since the brakes weren't working properly. The brakes got so hot that it slightly warped the rotors. So, he had to turn my brand new rotors. I'm not so happy about that, but at least the brakes are working now.
Old May 9, 2006 | 08:10 PM
reg's Avatar
reg
You should flush your brake fluid on an annual basis.............at least every two years. Brake fluid is hydroscopic and attracks water like a sponge.
R.
ORIGINAL: dinopix
mjwaterma
Sep 17, 2010 03:29 PM
nextproject
Nov 16, 2009 07:04 PM
rspi
Jun 30, 2009 09:51 PM
unclerichiezjr
Mar 17, 2009 07:38 PM
Alanbw
Oct 21, 2007 07:30 AM
