Bulb failure light
Old Aug 22, 2009 | 08:51 PM
schuckles's Avatar
Default Bulb failure light
Hi,
So I posted a few months ago with my 95' volvo 850. Since than, I installed a new timing belt, two new CV joints, and a slew of other things. But recently, I replaced the rear trunk support struts and one of which burst, leaking oil all over the rear brake light assembly. I smelled something electrical a few days ago and figured it was a relay. Since than the idiot light on the dash comes on when ever I use the brakes. I replaced all the bulbs, the brake lights seem to function properly, but the idiot light still comes on.
I'm wondering if I need to replace the bulb sensor relay?
Kind Regards,
Jon
Volvo 850 Manual transmission naturally aspirated 95' Wagon GLT
Old Aug 22, 2009 | 09:07 PM
Could be I would open the sensor up and inspect it.
I believe it is in the rear drivers side like under the side floor panel. It should be Blue.
Old Aug 24, 2009 | 01:41 PM
schuckles's Avatar
Default re: Bulb failure light location
I looked over by the top of the trunk but couldnt find anything. Is it bellow under the trunk carpet?
Old Aug 24, 2009 | 06:48 PM
Yes it can be like almost down by the bottom mounting for the tail light.
Old Aug 24, 2009 | 10:20 PM
schuckles's Avatar
Hrm... I tore up the trunk this eve, but didn't find it... I'll snap some pix tomorrow. This is driving me crazy. It's a wagon, not the sedan... I found a black device, when I disconnected it, the car locked it's self, so I'm thinking that is NOT it :-)
Old Aug 25, 2009 | 06:56 PM
Yes that is not it.
Old Aug 30, 2009 | 09:32 PM
schuckles's Avatar
Ok... So I found the lil blue box... its under the right side trunk lining, sorta hidden under a support beam for the car its self. But that was not the issue, it was functioning properly. The issue was the center brake light bulb was out. I'm a retard :-p
davej
Apr 22, 2011 08:47 AM
2005s60
Jan 19, 2011 01:50 PM
dcb07
Mar 11, 2010 01:41 AM
dads 740 turbo
Oct 24, 2008 06:54 PM
dreamcars80
Mar 28, 2005 03:04 PM
