burning smell
Old Oct 23, 2009 | 07:38 PM
samtheman77's Avatar
Default burning smell
A few months back i changed by turbo on nmy 94 850. Once in a while when im on the highway and using the turbo I will smell a bad smell, only when using the turbo it seems. My cat is fine, pcv was done a while ago. The turbo is not leaking or anything, any reasons why this is happening and any fixes?
thanks all
Old Oct 23, 2009 | 08:19 PM
boxpin's Avatar
Get a charcoal cabin filter.
Old Oct 23, 2009 | 08:25 PM
_HighVoltage_'s Avatar
How are your cam seals and the rear main seal? My main seal is leaking and I can smell oil when the revs get higher.
Old Oct 24, 2009 | 06:09 PM
what is involved in checking the main and cam seal?
better yet are these manageable tasks without pulling the engine?
Old Oct 25, 2009 | 08:28 PM
For the camseals you don't need to take engine out, but you do need to drop the transmission if the problem is with the main seal.
To check the camseals - look on the top sides of the engine. Basically if you can see oil anywhere on the engine it's bad.
To check the main seal - that's tricky. You have to look under the car.
Are there any drops of oil on the ground when you park it overnight?
pxl8ed
Nov 3, 2009 11:31 AM
BriGuy
Mar 5, 2008 04:56 PM
vipul_vips
Jan 26, 2008 06:44 AM
mywifescar
Apr 1, 2005 08:22 PM
ignacio
Sep 17, 2004 03:16 PM
