busted a/c?
Old Aug 16, 2009 | 04:27 PM
kapka42's Avatar
Default busted a/c?
a whiles back i hit a nasty put hole i didnt see doin around 30-40mph in my 95 glt. the hit was violent enough to crack my exhaust just behind my cat, so i got that fixed. around the same time i noticed the a/c stopped working too. It stills blows air which is kind of cold, but not really. its also really humid like outside. any suggestions on what could have gone? or am i just being paranoid, and all i need is a recharge?
Old Aug 16, 2009 | 04:50 PM
I would try having it recharged first. If there is a leak it should be seen then.
Old Aug 17, 2009 | 01:16 AM
Scott Baret's Avatar
If there is a leak the system will generally work for no more than one month if it is recharged.
How long has it been since work was done on the air conditioner?
Old Aug 17, 2009 | 10:27 AM
fcpgroton's Avatar
Former Sponsor
Once it is recharged, the freon should have dye in it so that if the system is leaking, you will see the dye and have the system fixed.
Old Aug 17, 2009 | 03:10 PM
kapka42's Avatar
i just bought teh car about a month ago or so. the ac was workin well, but stopped recently around teh time i broke my exhaust on the pothole too, so im not sure if it happened earlier or later, and i just didnt notice or its related to that hole. i guess ill try rechargin it and see what happens, couldnt poss hurt more than riding around without a/c during this heat wave
Old Aug 17, 2009 | 06:41 PM
kapka42's Avatar
i just bought a recharge kit today, and the pressure read a little above 100, that means im set on freon i suppose? i did notice when i turned it on and let it run with the hood open there was some noise coming from the compressor i beleive? it was located just under teh alternator. was makin a bit of a grinding noise kinda, nothing severe, but didnt sound quite like it was supposed to be like that. anyhow, with a recharge out of the picture, this would leave me with reshimming the clutch?
Old Aug 17, 2009 | 07:03 PM
It still might be low on freon.
Old Aug 18, 2009 | 02:55 PM
kapka42's Avatar
so then should i just remove the pressure/other junk and redo it anyhow? how would i go about removing the excess pressure without severely injuringmyslef/destroying my car and driveway?
Old Aug 18, 2009 | 07:25 PM
If you can swing it best way is to have a shop with a machine charge it.
ttundraman
Jul 22, 2007 06:52 PM
shwanzee
Jul 17, 2007 01:23 PM
northanger abbey
May 25, 2007 03:59 PM
mnala
Mar 1, 2007 11:48 AM
thatsmrgimp2u
Jul 3, 2005 06:50 PM
