A/C fan control unit
Old Oct 7, 2010 | 06:45 PM
rjv5n's Avatar
Default A/C fan control unit
MY slider fan switch only works on high. I am assuming that I have to replace the control unit.... I found one at the junk yard still in the 1994 850 sedan volvo. when trying to remove it there are three black cables connected to the back of the unit. does anyone know if those three cables disconnect from the back of the unit or do I have to find where they connect elsewhere???? Thanks so much Bob
Old Oct 7, 2010 | 07:29 PM
If it only works on high then the blower resistor might be bad.
Old Oct 8, 2010 | 11:15 AM
rjv5n's Avatar
can i confirm somehow that its the blower resistor, or just change it and se??
also is this something I can replace myself? can I get a used reliable resistor or buy new? Bob
Old Oct 8, 2010 | 07:38 PM
Usually when you only have high fan speed only it is the resistor. High fan speed bypasses the resistor. You might be able to find a used one but not sure.
You should be able to handle the swap.
jbridal
Penta
Nov 22, 2011 11:14 AM
alldway
Apr 12, 2008 09:00 AM
Rudy
Oct 3, 2006 08:36 PM
tomservo
Oct 2, 2005 12:30 AM
joneq
Aug 28, 2004 01:11 AM
