My Vacuum Hose Came Off
Old Oct 1, 2010 | 11:06 PM
MC92's Avatar
Default My Vacuum Hose Came Off
I was washing the car to day and when I looked under the car a rubber corner hose/pipe was off the vacuum system most likely fell to the ground. Anyone have a picture or diagram so I could put it back on? It had fell under between the engine and transmission would be. Took the car for a drive and nothing seems out of the ordinary. Thanks for the much appreciated help.
Old Oct 2, 2010 | 10:35 AM
Man, we really need more info about your car. Are you shure the hose came from your car? You would get at least a cel.
http://www.fcpgroton.com/category-ex...136/by_year/46
Old Oct 2, 2010 | 09:59 PM
MC92's Avatar
Well it's a turbo if that helps and yes it came from my car for I checked with the other vacuum lines that I could find and the ones I could see uses the some elbow/corner piece. PS. what's a cel??
Old Oct 2, 2010 | 10:23 PM
ibified's Avatar
cel = check engine light. Start by checking your vacuum tee, which is underneath your throttle cable cover which is on the right side of the motor as you are looking at it under the hood. You'll see a tube that sticks up that has vacuum lines running into it from various places.
Old Oct 7, 2010 | 05:18 PM
vjaneczko's Avatar
When you drove it, did you test the cruise control? It may have come from there if it's running well.
Old Oct 8, 2010 | 09:22 AM
I really doubt that a vac elbow would come off both connections. If it did come from your car, it was probably one left sitting on something after it was replaced and finally fell to the ground. Toss it in the glovebox and keep rolling.
Do you have a CEL?
Old Oct 8, 2010 | 08:28 PM
MC92's Avatar
What did you know, that's what I actually did. That's one more crap in my over stuff glovebox. The CEL never came on and if it was from the cruise control I'm not too worry, for I never use it anyway.
Newport_j
Sep 8, 2014 07:59 PM
blue02
Apr 4, 2011 05:46 PM
redrider4life1
Mar 20, 2011 05:59 PM
4cfed
Apr 9, 2010 03:58 PM
floryed
May 3, 2005 09:55 PM
