A/C Issue - Compressor?
Old Jun 22, 2006 | 05:35 PM
lysis's Avatar
Default A/C Issue - Compressor?
Hi, all.
I just recently started having just warm, humid air come out of the A/C (1997 850 Turbo - evaporator replaced at 40K under warranty). I hooked up a pressure gauge to the low-pressure port and it appears that the compressor keeps cycling between 20 and 45 every few seconds, so I'm assuming that I have enough 134a.
Am I right in assuming that the problem is either with the compressor clutch or the compressor itself?
Thanks.
Andy
lysis98@yahoo.com (get enough spam anyways)
Old Jun 22, 2006 | 06:24 PM
azeezn's Avatar
Default RE: A/C Issue - Compressor?
HI Andy,
I posted a post few minutes ago regarding my air conditioning now working and asking what steps I need to take to troubleshoot the problem. Since you are facing the same issue and seems to have tried out a few things, can you tell me how you started to troubleshoot it?
Thanx!
Old Jun 22, 2006 | 06:54 PM
SDozier's Avatar
Had the same problem last month (1995 850 Turbo). Turned out to be the clutch on the compressor. Repaired and is working perfectly. Cost : $600. High but it is working perfectly.
Old Jun 22, 2006 | 10:28 PM
projekteg's Avatar
you can get a reman. compressor for around 200 bucks and it's pretty easy to replace actually. i'm having the same issue with my 96 850 and after reading through the forums a bit, it seems it's a pretty common problem and is generally the compressor clutch if you've already verified that you have enough r134a in the system.
Old Jun 26, 2006 | 09:56 PM
Low on freon.
Buschwhack
May 14, 2015 08:47 AM
Tinkerbell1914
Jun 24, 2014 09:08 PM
sghokie
Jul 25, 2011 05:00 AM
99VolvoV70
Jul 22, 2007 11:08 PM
RonNaismith
Feb 28, 2005 07:24 PM
