A/C leak
Old Aug 11, 2006 | 05:46 PM
Dads850's Avatar
Default A/C leak
Yes, I know that the first thing to do is to check the evaporator and all that, but I really can't afford the $1000+ bill associated with a replacement. I've replaced the compressor (bearings were going) with a brand-new OEM unit plus I've replaced the receiver/dryer. I'm only going through 1 can twice a summer so the leak isn't too bad and am wondering if there is a good system sealer I could try to plug up the evap leak. If not, I can deal with replacing the 143a twice a year for 20 bucks. I've been reading about Duracool, but I wanted to check with the group before I did anything.
Old Aug 11, 2006 | 06:56 PM
96DTM850's Avatar
Default RE: A/C leak
suppose to be some kind of sealer you can buy at like Autozone or Kragen (whatever your local parts store is) for 19.99. Its a small can and seals A/C system's metal piping, etc. I suppose you can try that...you can rip apart your whole dash as one piece...I believe 2 bolts on each side then 4 or 5 bolts under the wiper cowl. Just do it the right way if you ask me.
Old Aug 11, 2006 | 09:15 PM
I would not try the Sealer.
I made a Post about replacing the evaperator. Look top of the 850 section.
Old Aug 11, 2006 | 09:47 PM
96DTM850's Avatar
ORIGINAL: tech
Agreed...just replace the d@mn thing...haha
Old Aug 12, 2006 | 02:39 PM
Dads850's Avatar
Yea yea yea.. I know. there's problems with that: I do not have another vehicle to drive while I'm working on it and I do not have a garage to work in. This is why I was thinking about a sealer or something.
Old Aug 12, 2006 | 02:59 PM
The sealer might Clog the orfice tube and cause High pressure leading to more problems.
Old Aug 13, 2006 | 11:22 PM
Dads850's Avatar
Okay, I guess it will wait until Spring or something.
Old Aug 15, 2006 | 05:25 AM
vern74's Avatar
I have just had the sealer put through my system. Can I expect bad things to happen ?
Should I keep a look/ear out for something in particular ?
Old Aug 15, 2006 | 09:06 PM
Just make sure it keeps working properly for now.
Old Sep 6, 2006 | 10:03 PM
vern74's Avatar
After I had the "sealer" installed it sounds as though the compressor is shaking itself to bits on start up ! Only lasts 10-20 seconds but sure doesn't sound good.
I thought it may have been the cooling fan but now think its the compressor....have I stuffed the system ?
Comments please
Old Sep 6, 2006 | 10:12 PM
Sounds like the compressor is bad.
Old Sep 6, 2006 | 10:31 PM
vern74's Avatar
Once its going its working fine
Its just the initial start that worries me
Sounds as tho the belt is slipping as well
Aslo causes nasty shuddering
Concerned it might be doing damage to other bits
Going on a trip soon and thinking its not going to last the distance
Old Sep 7, 2006 | 12:25 AM
You might want to have a shop look it over before traveling.
Old Sep 7, 2006 | 02:20 AM
vern74's Avatar
I appreciate your input
Cheers
2008XC70
2001-2013 model year XC70
Dec 20, 2017 03:07 PM
ROBLU540
Feb 20, 2009 07:59 PM
1999S80T6
Dec 16, 2008 04:54 AM
